New member Username: Hurleyashes25Post Number: 1 Registered: Mar-10 | Hey everyone, I am looking at upgrading my current system which consists of a 150 watt Infinity sub and 4 sattelite surrounds with a center channel. I want to upgrade my front speakers to Towers, and upgrade my Center channel to complement the new towers. I want to spend $600-700 and am running an Onkyo SR-507 receiver. I know the current rear sattelites probably wont initially perform on-par with the new speakers, but I'm doing this in installments. I listen to both music through my SPDIF-Optical port on my computer and watch movies on this system. I have been thinking about getting a pair of Polk Audio RTi-8's Towers with a CSi3 center. However, I know these are older speakers, and was wondering if there was anything newer, or better that would be in this price range. |
Gold Member Username: JrbayLivonia [Detroit area], Michigan USA Post Number: 1148 Registered: Feb-08 | Greetings Joe, Any chance that you can get to a store to audition speakers? That is the best way to tell if you are going to like them. Are your speakers all Infinity? If so that might be a good brand to try to find in a store (as well as Polk and as many others as possible) because then perhaps the old rears would match the new fronts. Happy shopping! |
Bronze Member Username: Vm8444Post Number: 96 Registered: Aug-05 | http://cgi.ebay.com/Boston-Acoustics-CS226C-Classic-Floorstanding-CS226-NEW_W0QQ itemZ170450659481QQcmdZViewItemQQptZSpeakers_Subwoofers?hash=item27afa6a899 boston acoustics give you the bestbang for the buck. Buy them anywhere hi joe get these match it with cs 225 center .. and get decent spk cables such as audioquest type 2 http://www.audioreview.com/mfr/audioquest/speaker-cables/type-2/PRD_116399_1584crx.aspx http://cgi.ebay.com/Boston-Acoustics-CS226C-Classic-Floorstanding-CS226-NEW_W0QQ itemZ170450659481QQcmdZViewItemQQptZSpeakers_Subwoofers?hash=item27afa6a899 the cs26 as rears http://www.amazon.com/Boston-Acoustics-CS26B-Classic-Bookshelf/dp/B001GCN3PU trust me with this and your home theater be the envy of your friends and sounds great with onkyo better then the polks. Make sure you read customer reviews for both models on amazon. does that help let me know theaudioguy.ca |
