What are transmission line speakers.
curious
what exactly are transmission line speakers? what are their pros and cons?and are they expensive?also, are they suitable for small rooms(audio only not HT).
Max
Hello,
Thats a good question and I hope somebody can answer it. I used to have some dcm transmission line speakers and I was always led to beleive it just means it has a horn loaded tweeter but I am almost positve I am wrong.
timn8ter
A transmission line is a quarter wave length tube or pipe. The length of the pipe is equal to 1/4 the wavelength of the drivers resonance frequency. The idea is to get a smooth response down to that level rather than the usual falloff. Bottom line: better, lower bass response than in other types of enclosures. Many QWT are tapered as a result of the work of Paul Voigt, hence the popular Voigt Pipe or Tapered Quarter Wave Tube (TQWT). For more in depth information visit:
http://www.quarter-wave.com
timn8ter
Oops, I'd better tell you about
http://www.t-linespeakers.org/sitemap.html
I don't want Dave to get mad at me.
