DENON 395 question...Help
Username: Jimmerz
My brother bought this brand new and it appears to be acting funny. Only connected 2 speakers to it currently. When you power it on, it comes on and for about 3 seconds goes to the fm tuner, but then you hear a click and it turns off. Nothing we did enabled this unit to stay on. it returns to stand by mode. ANY suggestions? Thanks
Username: Mike3
Wylie, Tx USA
Post Number: 1576
Unhook the speakers. If it stays on after you do that you have shorted speaker wire which must be replaced or corrected.
Do you have anything else plugged into the unit?
Username: Jimmerz
nothing else is plugged into the unit. It does the same thing whether the speakers are connected or not. He is in the middle of swapping it out for a new one, just wanted to make sure there wasn't something that needed to be done to activate it, or something crazy like that? Thanks
Username: Jimmerz
Thanks Mike. I posted another thread because he traded out the defective denon for a NAD T742. Hopefully he has better luck with that one.
