AV Reciever (programmability)
I'm trying to find an AV reciever to connect to a home theatre PC setup. It would be ideal if it had some sort of remote programmability. That is I can have the computer do things like turn up/down the volume, switch modes etc. Basically I'm looking for an interface to control the reciever.
The only thing I've found is an RS-232 port on some of the Marantz receivers. Mostly this looks to be used for firmware upgrades and the like, but I would find it difficult to beleive that there isn't inherently more functionality than that built in.
Any suggestions? Places to look?
G.DawG
The closest you are going to get is Logitech Z-680's I dont think there is a receiver that can do all that. Correct me if im wrong though :-]
Derek
This http://www.harmankardon.com/back.asp?prod=AVR%207200&cat=REC&sType=C one,
this http://www.sunfire.com/ultimatereceiver.htm#featured one,
this http://www.usa.denon.com/catalog/photo.asp?s=home&p=AVR%2D5803&f=5803%5FRE+21302%2Ejpg&c=2 one and
this http://www.onkyousa.com/model.cfm?m=TX-DS989ver2&class=Receiver&p=i one has RS-232. Though RS-232 is bi-directional, most manufacturers are using them to control simple things like projector screens. According to this http://www.hometheaterhifi.com/volume_10_3/show-report-cedia2003-page-1.html article, Extron and Crestron are about to make RS-232 do more.
Hope this helps.
Sweet. That helps quite a bit. I had all but given up hope. It still seems crazy that you can spend 2K on a good receiver, but they don't even have a network or web interface yet.
