Tweaks--Need a New Transformer
Username: Bssmith
Sydney, Nsw
I just arrived in Australia with my NAD C352 from North America. I have to replace the mains transformer so it will work here. Since I have to replace it anyway, can I improve the sound quality of the amp by replacing the transformer with something that has more volt amps? I was thinking of replacing the existing toroidal transformer with a custom wound one one that is 500va.
What sonic improvements might be possible.
Thanks
Username: Jan_b_vigne
Dallas, TX
Post Number: 12281
The transformer is simply one piece of the power supply and plays a rather minor role in overall sound quality. If you want to upgrade your sound quality, upgrade to better components rather than trying to design something you don't understand.
Username: Bssmith
Sydney, Nsw
Jan Vigne,
Thanks for the prompt response. I am replacing the transformer so the amp can function with the mains voltage and frequency here in Australia. My hope was that in the process, I could improve the sound from the amp and maybe begin a bit of a hobby at the same time. Any help you can offer would be appreciated.
Thanks,
bssmith
Dallas, TX
Post Number: 12282
"My hope was that in the process, I could improve the sound from the amp and maybe begin a bit of a hobby at the same time.'
My answer stands regarding upgrading the transformer. I don't know what you mean by the other.
