Will denon 1804 drive dynaudio audience 42?
Andy6221
my dealer told me that my 1804 couldnt drive audience 42, is that true? they said the 42 need 150 watt amps, please explain, thanks
Username: Sfox7076
Post Number: 15
Are you talking 2 channel or will you use it for 5.1 or 6.1? I have Paradigm Studio 60's, and the 1804 can drive them ok in 2 channel. Put it in 5 channel mode with a pair of Studio 20's as the rear and a CC center, and the amp dies. Not enough to shut down or anything, but you will be close to clipping it. There isn't a big enough power supply to power the Paradigms. The Dynaudios are less efficent than the Paradigms, so I imagine this effect will be worse.
Username: Sfox7076
Post Number: 17
Oh, they are 4 ohm as well. Yeah, that isn't a good idea with the 1804... At least I don't think it is.
Shawn
andy6221
any suggestion, what best will go for my 1804?
thanks
