Bookshelf Quad 11L/DALI?Wharf
Username: Deepakgang
Hi,
I am offered QUAD 11L at 560$ (1yr old)
DALI Concept 2 at 500$ (New)
I am also looking at Wharfedale Evo bookshelves(new).
Looks doesnt matter. Please can you suggest which one should I go for?
Username: Nuck
Post Number: 7096
Hi DP.
What is the rest of your gear?
hmm I will be using them with Cambridge audio CD player + CA Amp ... around 100 watts power to drive. I have heard good reviews about all the above models. I have to convince myself to go for a higher priced speaker just for the brand name. Like I ve heard Wharfedale 9.1s are great but im not sure how much diff Quad 11Ls will make to me. I like warm sound even a bit up towards brighter side.
Username: Nuck
Post Number: 7100
Is it a CA 540 or 640?
How do you like to listen?
Is the volume high very often, like filling a large listening space?
The quad's are quite distinctive, apart from the others.
mine will be a 3m x 4m room and the volume will be not too high and not too low also. I like to hear pop, country, contemporary pop, classicals etc. not much into metal. Also I am not sure ill get a demo here thats y im seeking help here.
and what about dali concepts?
Username: Markdavid
Post Number: 12
Hi DP
Quad is a very good speaker for the money and u wont be disappointed for the price u pay , i think ur cambridge will be a good if not the best match for quad , and Evo is better then diamond but its a budget speaker , not much entertaining . Dali is different all together .u have to listen to these before buying. i recommend quad or Evo.
