Polk RTi10 bi wire??
Username: Biga524
I just purchased
Onkyo TX-SR804
and the
Polk RTi10
Is bi-wiring good? I know how but can you do that with this reciever? or is it just a amp? thx
Username: Dmitchell
Ottawa, Ontario Canada
Post Number: 41
You bi-wire from a receiver as well. Not really sure what the point is... I tried it before and didn't notice any difference whatsoever.
Bi-amping is a different story altogether.
Username: Kano
BC Canada
Post Number: 1177
Yes bi-wire, I noticed better low end finesse with my Polk Rti8s
Username: Biga524
Post Number: 7
Kano..did you bi wire just useing a reciever or seperate amp? thx
Username: Kano
BC Canada
Post Number: 1179
Both, I initially bi-wired to the receiver. I connect with a banana into the receiver and bare wire into the speakers.
I later added a 200W x 2 power amp and noticed more bass, but the transitional bass improvement was the same between both receiver and amp.
