I'd like comparisons on the mentioned speakers. My amp is a cambridge audio 540a. Current speakers are wharfedale diamond 8.1s and Im looking to upgrade them. I listen to a wide variety of music including, metal, rock, reggae, dance and more. Note I also have a subwoofer (ruark vita 50, same as mja pro50).
I love the diamonds for the detail and speed. But I find they sound a bit jumbled sometimes and im after more precise imaging and a bit more oomph. (im keeping my amp btw). I just read a review on the tannoys and imaging is supposed to be immense. And looking at the price I just realised i saw it was for ONE dc1. So I would suspect they would be the better choice. Also with the diamonds the treble can sometimes seem a little lazy and too much (not precise enough although very revealing). Looking for a bit of magic.
When you say "Sound a bit jumbled" is that at higher volumes?
Yes the tannoys are crackers and the pick of the bunch IMHO.
Even the KEF are quite good at imaging as they have a wide sweet spot.
One more option if you would like is Diamond 9.1 much better than the 8.1s in all respect buy if you find treble lazy on 8.1s then the 9.1s are not far away for the same.
What CD player are you using as a source as it can play a big role in UNjumbling. Also what cables ?- some give a more sense of space between the instruments.
At higher volumes the clarity isnt as defined but I mean generally the sound isnt pure enough. Theres some mid bass missing somewhere and in the lower midrange that just sounds missing. They sound like they're trying to be to refined.
I suppose I can forget the tannoys, it would be the KEFs on the plate now. I simply cant afford the tannoys. I though I'd have my luck with £200 for some on ebay but theres over 35 watchers already.
I heard the diamond 9.1s from various people are pretty much the same, but with more bass.
Source is a soundcard, emu 0404 so its very flat and very configurable in terms of adjusting certain ranges of frequences which I have done to quite some extent. Interconnect is some custom one I had done for me over at headfi forums and works well, speaker wire is qed silver anniversary xt which is a noticeable detail improvement over my old gale 105 cable.
Hmm the KEFs would be a totally new experience. Kevlar and silk dome now vs metal!
You remember hey. Still mp3 yes, but more in vbr bit rates and higher bit rates. Besides, the point regarding speakers, I think the KEF iq 1s will be general step up. Do you not think?
High bit rate mp3s going through your sound card with an EQ are still mp3s JJ. Try as you might to squeeze juice from the turnip, you'd have an easier time squeezing from an orange.
Fine fine. Forget the speakers. Im just looking for something new thats all. Theres nothing noticeably wrong with my system Im just nitpicking as you could do with any system. I'll spend the money on my gf instead. lol
well to let you know. Earlier today I did a bit of moving things about. I moved them apart 3 metres but that really sucked because one was on an actual bookcase and one on my desk. Sound filled the room but there wasnt any imaging. So I moved them back to my desk and fiddled with my eq settings on my soundcard and changed stereo field back to 90 degress left and 90 degrees right for each respective channel. Then used the balance on my amp and turned it to a rather extravagent 9:30 o clock position which works much much better. I originally didnd to this because I thought it was going to ruin the sound. I love my diamonds wholefully. Imaging is far better theres definable instruments and engagement on the left of the middle of each speakers!! And I'll tell you why i turned it so far left because Im sat so close to my speakers. Monitors dont suffice as good enough. Detail has for some reason got better and layering is more defined! This is more like it!!! Im a happy bunny. At Easter :D
I definately cant find any room for stands. My room has a lot of things in. Im pretty satisifed now anyway. Its quite a different experience. Oddly different, the sound is a lot fuller and dynamic. Looks like this problems been sorted, I just wish i'd found out earlier by the simple move of one control. (because right speaker is closer to me so is quite significant with being sat so close to them).
Given the lack of experience with hi-fi I cant say I do. I couldnt miss the opportunity at £150 for a pair. Only problem is I have to wait up to a month for them to arrive because they're coming from Greece. although im currently negotiating fast delivery. I shall see. Although now im rather quite poor. I'm going to have to sell something to put a bit of money back into my account. I dont want to rid my diamonds because I like them. Anyone want to buy a powerball or battlefield 2142? I might resort to selling my sennheiser hd 280s!! *gasp*
