Help
ashels
I've had my durabrand cd player for maybe 2 months its the forth one i bought. The first one got dropped the second one got stolen and the third one i dont remember wut happened to it. Anyways the one i have now was playing fine this morning but this afternoon when i went to play a cd i could only hear out of one side of my headphones ive tried various headphones in my cd player and all are the same while the headphones work on other cd players. If i push the plug in on the headphones like up a lil and to the left it works. wut can i do about fixing it?
Username: Project6
Post Number: 617
get a fifth one.
Username: John_a
Post Number: 1309
Open it up, inspect, and you will probably see straight away that you can fix it if you bend the electrical contact/spring-clip so that, under its own tension, the clip makes contact with the jack.
