Help with speaker systems
Username: Brooks1
Huddersfield, England United kingdom
am currently looking to upgrade speakers, ie replace my walfdales with a better quality, ive recienty seen a set of bose 701 and wonder if anyone has sujestions on a possible alternative? have around £400 budget and require quite a substantial speaker as im currently producing about 1000watt rms, would appreciate any advise on this subject thanks Danny
Username: Nuck
Post Number: 6373
Danny, speakers are not the problem.
What is your current setup?
Speaks will not fix it.
I promise.
Username: Brooks1
what do u mean? u want specks on the full system or certian componants?
Username: Claudermilk
Post Number: 437
He means the Wharfedales are going to be better than any Bose you get. Look around here a bit & see how well thought-of Bose is (there's a reason they are nicknamed "Blows").
AFAIK Wharfedales are supposed to be pretty good. Also, is that 1000W RMS per CHANNEL?! Or perhaps total for the system, in which case what can it push per channel?
Username: Project6
Post Number: 13482
What system is this that can produce a whopping 1000 watts RMS???
Username: Stu_pitt
Irvington, New York USA
Post Number: 1623
McIntosh makes 1000 watt monoblocks. How much do you want to bet that the OP is running those?
Username: Project6
Post Number: 13489
Could be
Username: Project6
Post Number: 13492
Anyway, Daniel. I am thinking you do a lot of DJ work and you want something effcient(by looking at your equipment list...love those Technics turntables). Have you taken a look at professional speaker systems?
