Car subs for home system
Username: Brooksthepro
sorry if this topic has been discussed previously but i joined and am posting on this site from my cellphone so bear with me :-).
i have 2 12' subs in a box from my old car stereo. i want to hook it up to my harmon kardon reciever. i know i cant directly hook up the subs to the speaker out's on the reciever. and i know i cant use a car amplifier easily for my system......
now. if i were to buy this amplifier (DFX HDJ2000) and run rca cable from my reviever's sub built in crossover (sub woofer out) to the amplifier i want to get. will it work fine?....i wanna know it will work before i spend $200 on the amp.
TIA!!!
-brooks
Username: Project6
Post Number: 12760
It will work. All you really need is a proper amplifier that can drive the speakers.
is the hdj2000 not a proper amp for this setup? see link:
http://www.hollywooddj.com/dfxhdj2000.html
Username: Project6
Post Number: 12773
The amp can drive 4 ohm loads, just make sure that the speaker are rated at 4 Ohms.
Username: Gamerdude
Ontario Canada
Post Number: 387
Bryston if you have the money
ya my speakers are at 4ohms
Username: Project6
Post Number: 12783
Go for it and let us know how you like it.
thanks alot for you input guys. i will let you know how i like the setup!
