Boston Acoustics A 7200 Closeout
Username: Rusin
The Boston Acoustics A 7200 amp is currently being offered at Audio Advisor for $799.00 delivered. It's essentially the same as the Sherwood A-965. The specs are:
120 Watts per Channel from 20Hz-20kHz in stereo mode with <0.02% THD
Dual Toroidal
12 VDC Remote Turn On
Weight70.6 lbs
Dimensions (H x W x D)7-3&#8260;4 x 17-3&#8260;8 x 1-3&#8260;4 inches
I understand BA is closing these out and getting out of amp business. Sounds like the fact that they've been purchased by Marantz /Denon group may have influenced this.
Would appreciate impressions about the value of this amp?
Username: Dakulis
Spokane, Washington United States
Post Number: 929
The reviews have been OK. The Sherwood unit generally gets decent reviews. BUT, go listen to one with speakers you like and see if it floats your boat.
The price is certainly right as NADs, Rotels and Adcoms with similar specs are closer to the $1200 range.
