Impedance mismatches and other speaker issues
Username: Sriram
Hi All,
I am looking to buy the Wharfdale Diamond 9.6s and a receiver that I have not decided upon. The impedance rating on the speakers are 6 ohms. I see that most ratings on receivers is 8ohms. Is this mismatch something that I need to be concerned about. If the receivers has 'Low impedance drive capabilty', will it help me circumnavigate the issue.
While at this any suggestion on receivers in the 600$ - 1000$ range that blend well with the Wharfdales would be very helpful.
Thanks and Cheers
Sriram
Username: Edster922
Post Number: 3869
Harman Kardon 635, $630 shipped from vanns.com should handle them easily, if you're looking for a surround receiver.
Username: Project6
Post Number: 7555
I highly recommend the Outlaw Audio 1070
http://www.outlawaudio.com/products/1070.html
Username: Hawk
Highlands Ranch, CO USA
Post Number: 809
I personally would recommend a Marantz SR5600 or SR7500, either of which is a good match for your speakers and within your price range. Wharfdale Diamond 9 series is pretty forward sounding speaker, as I recall, and a receiver/amp with a little more laid back, warm sound would be the best match, IMO.
Username: Sriram
Thanks for your inputs, I have a few more queries..
1. what exactly does forward sounding speakers mean.
2. Warm tones are what i am looking for, so what are your comments about Denon AVR 3806 or the AVR 2807?
Thanks
Username: Edster922
Post Number: 3872
1. music sounds like it's coming from the front of the speakers, as opposed to from behind the speakers ("laid-back")..."forward" is usually associated with "bright" but not by definition
2. Denon is not known for "warmth"---that would be Pioneer Elite, Marantz, and to some degree Harman Kardon.
Username: Nuck
Post Number: 2224
As opposed to 'thin' which may include Yamaha, Denon or Onkyo.
Thin would mead lean, no weight, regardless of the program or frequency response.
Username: Hawk
Post Number: 829
Nuck is right. "Thin" is the result of using crappy power supplies . . .Yamaha, Denon and Onkyo are the worst offenders (the "ususal suspects").
Username: Hawk
Post Number: 830
Oops, that's "usual suspests."
Username: Hawk
Post Number: 831
Oops, that should be "usual suspects."
Username: Nuck
Post Number: 2250
3 balls for a quarter, Hawk.
