Kef 104ab cable connector nuts
Username: Mr_capstick
LondonEnlgland
I'm after some of the cable connectors for the back of a pair of Kef 104ab's. For some reason these have been removed.
All help appreciated
Username: Jan_b_vigne
Dallas, TX
Post Number: 7148
I'm afraid I don't know what exactly you are trying to find. If the top nut of the biniding post has been removed, the best choice is to either (cheap way) simply use a nut from the hardware shop or (best way) buy entirely new five way binding posts and replace the entire assembly.
LondonEnlgland
Sorry if I did'nt make myself clear. The actual connectors that connect the cable to the back of the speakers are missing?
Dallas, TX
Post Number: 7153
What connectors? The binding posts?
LondonEnlgland
I'm not sure there's just 2 threaded holes?
Dallas, TX
Post Number: 7158
Can you get inside the speaker? Usually the easiest way is to remove the woofer.
Notamember
Those holes are sockets for banana plugs. If you look closely at the black plastic surround, you'll see a plus sign molded next to the positive socket, and a minus sign for the negative socket. Any standard single banana plug will work, but the spacing is wrong for double banana plugs. I don't know why KEF used this hookup system.
