purchased a MPIO FL600 as a Christmas present for my wife. The set up was smooth, and my wife easily created her own playlists.
When I tried to make my own playlist, I filled the gig, and then the player froze up. I turned it off and when I turned it back on it just said "please wait". I waited and eventually it went to the root directory. Ther were many files represented by different symbols and/or languages (ex. >@p8!. ) "My list" and "record" are also there but they do not work.
I tried following the directions in the adobe file using the mpio utility to format the player, but I ended up with the same result. I can still drag and drop files into the player, and my PC will recognize the player. My PC however will not recognize the .smx files. I simply can't get back to the default settings. The FAQ on the website does not help, and the adobe file does not help me either.
I went back to the store (Future Shop) and the clerk had never experienced a similar problem. Any help would be greatly appreciated. Thank you for your time.
