Amp Problems
David W
I have a 6 year old radio shack 250w pa amp hooked up to my sub. The right channel needle moves just as the left does, however turning up and down the right channel, while the needle does move more or less, it produces no more or less response by the sub. Any suggestions? Might this be related to my grounding problem I have had in the past? Thank you for your time, David
