Phillips FW 650C/21M Help Please!!
Username: Anitav
A number of problems with the lil machine.
1. The cd player doesnt work, the message says "can not play CD" i opened the case thinking if i cleaned the laser it might work but when i opened case a cable came out....which leads to problem 2.
2. It doesnt turn on anymore...:-( the cable is thin and white on both sides, flat with writing that says "sumitomo-s AWM 2896 80C VW-1". I know where one side connects to (the bottom middle of motherboard) but i cant seem to find the other socket.
I know this sounds like the most ridiculous of questions but any help would be appriciated! TA!
Username: Anitav
I forgot problem 3
3. When it did turn on you could bearly hear anything on full blast. I checked the speakers on my other stereo and they work fine. I also put in headphones and still the sound was very weak.
Username: Gamerdude
Kitchener, Ontario Canada
Post Number: 10
I'v owned tons of philips audio over the past couple of year and they have worked fine
Top Deals
Loading, please wait...
Need to Register?
Forgot Password?
Enable HTML code in message
Top Deals
