Which speakers and sub should i go with for my system. This is my first system that i have built and i know what i want for sound. It is going to be used for about 80% music, 10% games and 10% movies. I was deciding between the HKTS 14 and the athena point5 mkII speaker systems, but i dont know which sub to buy with that combo (point5). do athena subs sound good? and also visual aesthetics will play a part in my decision as well. Thank you!
If you like your (80%) music loud, I would not get a small speaker system. With the strong power of the AVR435 at least look at some bookshelf speakers on stands or mounts for the front. This will give you much better two channel sound when you are playing two channel source material. If you were watching 80% movies I would advise you differently.
