Help! arcam or denon
I am getting dali suite 2.8 speakers. They are 4 ohm. I wanted to get denon 3805 but was afraid would not be able to drive the speakers.So i decided on arcam300. I am not sure it is the right decision. perhaps I could get the denon and add an amplifier to drive the fronts. it is almost 1K difference between arcam and denon. if I go for denon and amp it will be even. what is my best choice to achieve the best sound at this price level?
please help.
Username: Mike_6289
Post Number: 10
go with denon.. usually good amps with big power supplies can drive 4 ohm speakers
Are you planning on 5.1 or 7.1? If 5.1 you can by amp with the Arcam. Also check out http://www.iar-80.com/page130.html It is a review soon to be published in Widescreen review.
After reading this you would be a fool to not buy the ARCAM
Jump to: Home Audio Forum | Home Video Forum | Home Theater Forum | Car Audio Forum
