Subwoofer novice.
Username: Earski
Post Number: 13
Hello,
I have a Pioneer Elite-54TX paired with MA S6's front and S1's rear. Very nice, tight, bright mid and high audio reproduction but lows suffer. I primary listen to audio but at some point will implement surround-sound as well.
Anyway, I want to implement a sub to add the low-end kick the MA's don't provide (Need this when I listen to Pink Floyd). With this said, is there anything special I need to consider? Will my music be reproduced through the sub or is there something I'll need to do to make this happen other then connect the sub to the LLI port on my receiver?
Any assistance you might provide is appreciated.
-David
Username: Dloweman
Post Number: 56
Nope, just get a good sub and connect it to the sub preout and you are set. I would suggest an Hsu sub.
Username: Earski
Post Number: 14
Thanks d lowe! I've already received some feedback from Dr. Hsu.
Username: Dloweman
Post Number: 69
Sounds like you are well on your way to finishing a very nice system. Enjoy
