Best Speaker for HK 430??
Username: Dchui
Calgary, Alberta Canada
I listened to 3 different speakers, which are
Infinity Primus 360
Polk Audio RTI 8
B&W 602 S3
They are about the same price and the B&W sounds better in the show room, which is driven by Rotel amp. I would like to ask if B&W will work well with HK 430? Are there any other good speaker anyone can recommend in this price range?
Username: Odt
Bangna, Bangkok Thailand
NHT SB3
Username: Classical
Los Angeles
Post Number: 8
A lot of it will depend on the type of listening. I have Polk RTis and they sound really great with most everything -- except choral. Not too sure yet why this is, but I would advise you to take a good listen to the midrange of each speaker brand. You may want to use a good piece of female choral music, even if you despise it, as the test material.
Username: Project6
Post Number: 2422
Scruffy, have tried the Magnepans for your choral music?
Username: Classical
Los Angeles
Post Number: 9
You may also want to consider what some people consider to be the "fatigue" and "forgiveness" factors. When I compared the B&Ws to Paradigms, my first reaction was that the Paradigms sounded better, but listening more carefully using different types of music, I began to see where the B&Ws seemed to do a better job "forgiving" certain types of recordings. Same is true for the amount of time you spend listening. What sounds better for short term listening pleasure can easily get reversed in the long term. In general, "warmer" speakers, like the B&Ws, seem to produce less fatigue and are generally more "forgiving."
Username: Dchui
Thanks for the input
Ok, i will check out the NHT SB bookshelf speaker. Need to find out where i can hear them.
My system is going to sit in my living room(15'x15') and is used 50/50 for movie and music. For music it is 70/30 between classical and pop. I am going to use Monster 12 Gauge wire to hook up the whole system. I don't really trust what i heard from the B&W showroom since they are using more hi-end amp and Cd player, and their showrooms
is well made for testing speakers. So, besides NHT, are there any speakers can work well with HK 430??
Username: Petergalbraith
Rimouski, Quebec Canada
Post Number: 287
There's Klipsch.
Username: Dchui
Just an update for this thread.
After reading so many reviews and also helps from all of you, I just ordered the Axiom Epic 60 package. I will spend a month to do direct comparison with the B&W 602 S3/LCR 600/601 S3 in my living room. Just hope that in the end i will be happy with the Axiom, otherwise i need to pay shipping to return them. >_<
Again, thanks for the help
