Using 4 speakers with one amp
a have an amp, it has only two outputs, on last disco i used 4 speakers, connected i pairs, but i couldnt get enough pover, and amp kept hot, and turned off, ewen if preamp was only yellow (almost red). give me some advice hov to connect speakers to get maximum effect, not burning down the amp. 4 identical speakers, pioneer amp witout any cooling.
What do you mean? Where are you from?
