Good speakers match for nadc320bee
tago mago
Hi all.
What do u think would be the best speakers pairing with the NAD C320BEE? In particular among the following brands:
Mordaunt Short
B&W
Chario
Magnat
Indiana Line
I've read somewhere that the NAD is not very good with heavy rock. Any opinion about this? I listen to a lot of alternative/underground rock.
Cheers.
Username: Destro713
Chicago, IL U.S.A.
Post Number: 16
Sorry, I have nothing to say on the matter, but I had to respond because of your username. Great album. Great band.
Username: Pal
PuneIndia
Post Number: 57
I'm using B&W 602 S3, and it rocks...
u can also try PSB
dnnyt
anyone has try this NAD (C320BEE) with mordaunt short 902
how's the sound????
tago mago
Yes opinions/experiences on pairing with MS 902,904 906 would be quite interesting.
Cane141
Hi
I have the NAD 320BEE with the Chario SYNTAR 200 (bought them 340€ in Greece) and it sounds pretty good on indie/ aletrnative guitar stuff that I mostly listen to (never tried any CAN alboum though).
I have also tried the B&W, various Magnat models and other speakers (KEF, Tannoy, JMLab) and Syntar's were clearly better (more clear sound and better bass).
Still, having said that, I would opt for a more 'complete' sound that I dont seem to get from the Syntars (it's a bookshelf speaker after all).
tago mago
After some research i have thought about the following possible matches. I like floorstanders and i listen to a lot of stuff other than rock,from jazz to experimental electronic: basically i listen to everything other than mainstream :-)
What do u think about?
Nad C320BEE + B&W DM602.5 S3
Nad C320BEE + Aliante CNM Tower
Nad C320BEE + Indiana Arbour 4.20
Nad C320BEE + Mordaunt Short 904
Nad C320BEE + Tannoy Sensys DC2
Nad C320BEE + Chario (don't know which model)
