I have a DP-51F.The wires have come off the headshell.Does anyone know the correct order to put them back on?I believe the top left is white and the top right is red but not sure about the blue and green.Any help greatly appreciated.
J. Vigne
If you will take a V.O.M. and check for continuity you can be certain of a correct hook up.
Kajtsu
I have a DP-51F with Shure M97 HE and the wires goes from top white-red-blue-green. It has been so about 20 years.
