Marantz SR4500
Username: Ronk11
Bloomington, MN US
Anyone know where I can find the new Marantz 4500? I have not yet hand any luck finding it on the net nor at a local dealer (MN Twin Cities).
http://www.audioholics.com/cedia/cedia2004/marantzsr4500.php
Thanks,
Ron
nine
sir ron....im planning also to buy this receiver(here..manila,PH.....any comment on this...i cant find any review on this receiver over the net...tnx... and also...is it just fine if ill use it to power my B&W 602s3...cc3 n ds6...tnx so much...
nine
any updates on this ....
Username: Ronk11
Bloomington, MN US
Hello, I am looking for a new receiver also. So I do not have advice on the equipment you are hooking up. You probably should just start a new Post asking questions that the moderators can answer.
I have only been able to find the one review I have in the link from my original question. You can maybe call Marantz directly?
www.marantz.com
Good luck,
Ron
nine
ok..tnx sir ron.........
cubby
Anyone purchased a marantz sr-4500? Any comment on this receiver? I'm planning to upgrade from 5.1 to 7.1 and has been considering the sr-4500.
Username: Landroval
Post Number: 905
Here (4500):
http://www.avsforum.com/avs-vb/showthread.php?s=&threadid=426057&perpage=20&page number=7
And here (5500):
http://www.avsforum.com/avs-vb/showthread.php?s=&threadid=426057&perpage=20&page number=9
Username: Ronk11
Bloomington, MN US
Thanks "landroval"! This sounds pretty impressive. I want one, if I can find it???
-Ron
Username: Ronk11
Bloomington, MN US
Post Number: 7
Landroval,
Can you tell me what "Lip-Sync" is? Someone stated they went from the 4500 to 5500 because the 4500 didn't have "Lip-Sync"???
Thanks,
Ron
Username: Landroval
Post Number: 907
Lip-sync means you can delay the audio between 0 and a few hundred ms so that the sound will be syncronized with video stream of new plasma/lcd tv's/projectors which have a slight delay on the video output.
Username: Ronk11
Bloomington, MN US
Post Number: 8
Thanks Landroval!
-Ron
cubby
landroval,
thanks for directing us to avs forum. I've read Myki's user review of marantz sr4500, and it sounds good to me. i can't wait to grab one for me and test it myself. for a price of $300, i think it's a bargain.
Username: Impala
hi all! does anyone have an sr4500/wharfedale diamond 8(or 9) setup? do they sound ok, good or great? is the marantz receiver a good pair with the diamonds? hope somebody can help soon coz' i'm really eager to buy this weekend. tnx in advance!
