Connecting DVD and Mixer to the same Input Source
The Kim
I was able to connect my DVD Coaxial to the DVD Coaxial AMP and the Mixer Analog to the DVD analog. Then play DVD and sing karaoke through the mixer mic. After I changed the dvd coaxial to optical, the mixer no longer works even if i replace the coaxial. The only time the mixer works is if I remove the coaxial or optical connection. Can anyone help me?
Username: Project6
Post Number: 122
go to your dvd set up and see if anything has changed on your outputs. make sure that your are still putting out analog stereo.
cheers
