Ceiling speakers amp ?
Username: Ron6962
I have tried two different receiver/amps to drive 6 pairs of ceiling speakers. One Sony and one RCA, both 500 watt systems. They work for a while, then either blow an internal fuse (Sony) or give me "amp err" (RCA) error. The user guides do not help. Any suggestions? Thanks.
J. Vigne
What type of switch box and volume controls are you hooking between the amp and speakers?
Username: Ron6962
Thanks for the response. I do not have a switch box....just a separate volume control in each room for each set of speakers. Most of the time the volume is off in all but 1 or 2 rooms. I have never tried running all the speakers at the same time, but would not usually want to do that anyway.
You need impedance matching controls or switching.
Or you need to get creative with the whole parallel/series thing. If you're running six speakers in parallel, you're probably giving the amp a heart attack because it's "looking" at almost a dead short.
Username: Ron6962
Bingo! Thank you so much for the advice. I have now determined that is exactly my problem. The individual volume controls were not impedance matched appropriately for my amp. Thanks for the response.
