I CANT SEE MY GAME
Username: Smb197592
I'm trying to hook my ps2 up to my tv and I cant figure it out. I normally hit video source on my remote((time warner cable)) but I recently got a new cable box and it's confusing. The cable box is scientific atlanta explorer 8300 and thats what I plugged my red yellow and white cord into. I tried plugging them into the tv also and just changing the channel on the tv but that didnt work either. Everything else is plugged in correctly I just don't know how to find my game! Please Help
Username: Bud_gld
Post Number: 12
The jacks on the cable box are outs u cannot plug into it. U have to plug the av jacks into the tv then switch the tv input to the setting that the ps2 is in and should work.
Username: Insearchofbass
Post Number: 16416
x2
Username: Stiven
Connect the set-top box to another TV. Thus, you can check if your TV or set-top box works for you.
Need to Register?
Forgot Password?
Enable HTML code in message
