How can I improve my wired connection from ps3 to the internet?
Username: Cristorad3
I don't understand what is wrong with my connection. My connection to the internet from my pc is perfect and it's a wired connection, not even a wireless connection. It is sometimes good and sometimes bad and fluctuates a lot. How can I solve this problem? I use a netgear router and it is located right next to my ps3.
Username: Nelsters
are you using virgin media, if so it could be that you have the old 100 120 modems, what speed are you using because they dont support any faster than 10 meg
Username: Insearchofbass
Post Number: 16394
wow that would suck
Need to Register?
Forgot Password?
Enable HTML code in message
