Do i have to switch my xbox to 1080 manually??
Username: Hannibal26
do i have to switch my xbox to 1080 manually??
xbox 360 i mean
Username: Antidestro
Smithville, Missouri USA Baby
on the a/v side that plugs into the console there is a switch that goes from tv to hdtv... switch it to hd and it auto turns it to a high def, i am not sure which but your better off with 720p... get to the 360 dashboard and go all the way to the right is the system "blade" and you will find what your looking for there to change it from 480 all the way to 1080
Need to Register?
Forgot Password?
Enable HTML code in message
