Halo 2/DLP lag solution?
http://www.crutchfield.com/S-VbPpsALXSh9/cgi-bin/ProdView.asp?g=87500&I=119XGL40 0
Has anyone tried this product or something similar and had any luck? I'm looking for something to eliminate the 1sec lag while playing 480p games such as Halo2 on a DLP screen.
Username: Aclhunter
I bought the Xbox HD AV Pack, it works just as good as the overpriced Monster Cables
I'm looking for the Sony Component Cables for my PS2 but I can't find 1 store that has them in stock :\
Need to Register?
Forgot Password?
Enable HTML code in message
