Computer Stereo Line Out, Connecting to a stereo,wire type, etc.
Username: Jimmmm
NY
How far can i run a 'line level out' (audio line out) from a computer to a stereo/amp without boosting signal ? (Actually it seems to be a stereo out that has a variable sound level via a control panel, would it be O.K to turn computer volume control panel all the way up?)
To run a Line level approx. 20 feet : Can i use speaker wire ? , Will Category 5, 5e, or 6 be O.K ? unshielded/shielded ? , or will i need shielded coax ?, rg6 or rg59 ?
I have access to all of these wire types , please comment on each of these types of you can.
How Many times can i split the Line Level and send to different stereos/amps before using a mixer or preAmp ? At least 2 or three ?
Will signal degrade for either stereo/amps ?
Thank You For Your Time !
Need to Register?
Forgot Password?
Enable HTML code in message
