Boosting Wireless Strength
tvshopper
I am running a Netgear wireless router with a Dell (Citrix) wireless USB adapter and the signal isn't what it should be sometimes. I am looking for ways to boost the signal short of purchasing the RangeMax router. Any ideas?
Username: Zulkir
U.S.A.
Post Number: 15
keep it away from as much electrical interference as you can. move it around till you find a good spot.
Username: Seanpenn
Post Number: 9
Might be because other wireless are interfering with u
Goto your wireless settings and move the one you are connecting to on the top of the list.
Need to Register?
Forgot Password?
Enable HTML code in message
