Problems With Echo Indigo IO and 96KHz ...
Username: Blazingarrow74
Chicago, IL U.S.A.
Post Number: 54
Hey Everyone ... I am currently transfering to my computer, high-quality DVD Concert Music using the Audacity program and my Laptop Sound-Card (with Line-In and 24-Bit/96Khz Ability) ... However, whenever I record audio at 96Khz, the playback is always warbled, even when I lock my soundcard at that sample rate (96KHz) ...
I've tried the frequency 88.2KHz, and both recording and playback were perfect ... I use an Echo Indigo IO sound card and am absolutely sure that 96KHz sampling is suppoted in both recoding and playback ...
Is there something I do not know about sample rate compatabilities or something ? ... Audacity supports sample rates far beyond 96KHz (Up to 192KHz) so I am also sure it's not the software I am using that's causing conflict ... And I have more than enough RAM (1 GB), I'm sure, to allow the sample to run smoothly ... Any Insights or Help Are Greatly Apprecited !!
Need to Register?
Forgot Password?
Enable HTML code in message
