Top 6 Steps to Connect Bluetooth Keyboard with IPad
Username: Lorry2010
The iPad's larger screen makes typing on its on-screen virtual keyboard easier than typing on the iPhone . However, most heavy typists will attest that typing on the iPad will never be as fast as typing on a physical keyboard. The iPad does have Bluetooth keyboard support, which helps increase typing speeds when writing longer documents or emails. Then I will tell you how to connect bluetooth keyboard with ipad.
  1. Turn on your Bluetooth keyboard and make it discoverable by other Bluetooth devices.
  2. Tap the "Settings" icon on your iPad to open the Settings menu.
  3. Select the "General" tab, then tap the "Bluetooth" option.
  4. Press the "Off" button under the Bluetooth heading to turn on the iPad's Bluetooth radio. The iPad will now search for and list devices it can connect with.
  5. Tap the name of your Bluetooth keyboard when it shows up on your iPad. A PIN number will be shown on the iPad. Type this number on your Bluetooth keyboard and press "Enter." The iPad and keyboard will now be paired.
  6. Open an iPad application you can type in, such as Notes or Pages. You should be able to type with the Bluetooth keyboard.
Article Summary: In the final analysis, the bluetooth keyboard can help you send documents and emails more quickly, and those instructions will help you connect bluetooth keyboard with your ipad.
Need to Register?
Forgot Password?
Enable HTML code in message
