Microsoft office xp pro
Username: Joshockey
Post Number: 23
i recently had to reboot my computer and having to clean the hard drive well for some reason microsoft office doesnt work and i have lost the cd key i tried a key generator and after all the combonations i still cant find one that will work any help would be apreciated
thanks
Username: G3nocd3
San Jose, Ca USA
Post Number: 290
keygen.com. Its your choice, you take the risk, keygens are illegal, So its your choice. your risck. Do what you want just be careful.
try kazza, or better still edonkey or its sister emule, their all p2p sharing programs, but the last two are heavely focused on programs. hope this is some help. for ever may socialism exist! viva le revelution!
Username: Illuminator
Post Number: 2203
I wouldn't recommend ever looking for keys/serials/activation numbers. In the long run after much searching you'll find one that works, but the massive amounts of viruses and trojans just aren't worth it if you don't know what you're doing.
Username: Rowlandbrown
Post Number: 34
Tim - keygens are only illegal when you don't own an original serial. If you have an original then you can use another serial if you want. It is just like having a CD it is legal to "back up" (copy) your own CDs as long as you have the original.
Username: Coolwazabi
Nashville, TN United States
Post Number: 52
i agree with jexx and rowland...
Username: Evadelparaiso
Puerto Rico
Post Number: 1886
jellybean software for when do you need pass recovery from already installed programs in your pc.
http://www.magicaljellybean.com/keyfinder.shtml You can download free from Web. Work great
Need to Register?
Forgot Password?
Enable HTML code in message
