Need Advice on C inspire digital 5700 & Audigy 4
Username: Jay007
West GlamorganUnited Kingdom
hi all,
Looking for advice on the best connections to use to get the most out of Creative inspire 5.1 digital 5700 & Audigy 4 soundcard ??
Any advice appreciated..
at the moment im using the analog ins, but no sound from the centre speaker, so would love to get this lot working properly.
What cables would i need to get this working ?
i really dont have a clue.
Thanks all...
Username: Andreas
Post Number: 9
First of all you should get 5.1. sound when using analog connections. I would not jump to digital just because analog does not work. Must be wrong settings or faulty cable maybe. Make sure you set card to 5.1. and activated analog inputs on the 5700 control unit. Alternatively you can use digital connection. Check creative's knowledge base on their site, it's very good, with pics and all.
Need to Register?
Forgot Password?
Enable HTML code in message
