Sound card dual output
Username: Noodle
Beaverton, OR USA
I am setting up a home theater to run off my computer. This setup will have a 5.1 home theater speaker set in an adjacent room, in addition to my normal 4.1 PC speakers. Assuming I purchased a receiver that does not have A/B zone switching, would it be possible to install two sound cards on my computer, sending the output of the first one to my receiver and the second to my PC speakers? I want to have the ability to play music on all the speakers at once.
Username: G3nocd3
San Jose, Ca USA
Post Number: 61
gl with that one. I say run your soundcard to an a/v receiver and then route the speakers. Save you alot of trouble but cost $$$
Username: Arrow224
Post Number: 58
Yes, you can hve two soundcards in one PC. Eg, if you are a DJ, one for you, and one for the crowd.
Need to Register?
Forgot Password?
Enable HTML code in message
