Hi8 tapes played on 8mm camcorder
Username: 99hathaway
is the quality of the video degraded when a Hi8 tape (ie recorded on a Hi8 camcorder) is played on a 8mm camcorder ??
Username: Ieee488
Post Number: 477
According to http://en.wikipedia.org/wiki/8_mm_video_format#Hi8 your 8mm camcorder won't be able to play the Hi8 tape even though the tapes are the same size.
The way the information is encoded on the tape is different.
Username: Matthawkins
Post Number: 13
Agreed. I don't believe you can playback Hi8 video on a normal 8mm camcorder. However a Hi8 tape might contain video in normal 8mm format so it's worth checking.
Need to Register?
Forgot Password?
Enable HTML code in message
