Work in progress
Username: Shovelhead
E.Hartford, CT USA
Here is the start of my setup.
The monitor on the wall is a 45" Sharp LCD Aquos hidden behind a mirror (It's from www.seura.com) and still wrapped in plastic.
The receiver is a Yamaha RXV-757 hidden inside the early 1900's mohagony antique. The 7.1 speaker sound is from JBL (looking to upgrade in the very near future). All the cables are hidden inside the wall. Will post more pictures in the future.
E.Hartford, CT USA
Addedd the curios from Howard Miller on the sides as well as the custom made Bradington-Young leather recliners. I am still searching for that right table for in between the chairs.
To keep as simple as possible I went with a cable card instead of a box.
The DVD player is from LG an sitting up on top.
Right below it is a powercenter from Monster.
Calrad supplied the speaker selector (A speakers are my 7.1, and B speakers are ceiling mounted throughout the basement--8 ceiling speakers total from Polk)
The receiver sits all the way on the bottom. I thought that it would get hot so I purchased a fan, but no need to use it as of yet.
Need to Register?
Forgot Password?
Enable HTML code in message
