Bare speaker wire convert to RCA
Username: Lostprincessofoz
I have some speakers that I bought to connect to my turntable. HOWEVER, the speakers end in bare wire and my turntable only takes RCA 3.5 mm (red/white). Is there any way to splice them directly on the speaker wire? Or do I need an adapter/receiver?
The more research I do the more it seems soldering would be involved to add the plugs. Is there an adapter box that I can clip the wires in on one end that has rca on the other end?
Edit: The back on the turn table for Audio out reads "8 OHM" and easily fits the red/white rca cables. Also wondering, would banana plugs work, or are they for headphone sized input/output?
Username: Project6
Post Number: 15912
What kind of turntable is it? Unless it has it's own amplifier, you need to connect the turntable to a receiver and NOT} directly to speakers.
It's old school...Sears sr3000 Compact Stereo with AM/FM, phono & tape. Here is a link to someone selling the same bad boy. http://www.proxibid.com/asp/LotDetail.asp?ahid=3280&aid=37317&lid=10045604#
Need to Register?
Forgot Password?
Enable HTML code in message
