Connecting Blu Ray's Digital Audio Coaxial Output to TV's RF input (a.k.a. Cable TV Input jack) possible?
Username: Adrien23
Is Connecting Blu Ray's Digital Audio Coaxial Output to TV's RF input possible?
I know it sounds strange, but please bear with me. I'm just curious if this would work.
My TV's RF (coaxial cable, for cable TV) Input jack is free since I use HDMI with my cable box. I am curious whether connecting some sort of cable from the digital coaxial audio output of my blu-ray player to the RF input of my TV would work for audio?
If so, what cable(s) do I need or adapters?
Thanks,
Adrien
P.S.
I know this is atypical, especially since I don't have a home theatre setup. But I'm just wondering if this is possible.
Thank you!
Username: Ieee488
Post Number: 471
http://www.gefen.com/gefentv/gtvproduct.jsp?prod_id=5980
Username: Adrien23
I'm an audio newbie, but that might be a solution if the coaxial audio was an input not an output as is the case with my Blu Ray player (it has a coaxial audio output).
My TV has an RF analog input and my Blu-Ray has a digital coaxial output.
Maybe there's something I'm missing?
Thanks!
Username: Ieee488
Post Number: 476
digital is NOT analog; hence you need the converter box
if that is not something you understand, then just go ahead and connect it up and see what you get
Need to Register?
Forgot Password?
Enable HTML code in message
