Side entry banana plugs
Username: Tedstyler
Stupid noob question...
how am i meant to connect the side entry banana plugs to the speaker cable. Do i just shove the bare wire at the end of the cable into the hole at the side and thighten up the end to compress them??
Pictures would be helpful....
You guys are cool, peace.
Username: Tedstyler
Also another rather silly question...
I'm using Chord Carnival Silver Plus bi-wire cables, do i need to get rid of the polyethylene around the wire before i put the cable into the plug, or do i just strip off the outer layer?
Thanks,
Josh
Username: Illuminator
Post Number: 5208
Exactly. The 'tightening up' is actually called 'crimping' and is best done with a set of crimpers...or pliers if you're really cheap haha.
Need to Register?
Forgot Password?
Enable HTML code in message
