Room brightness
Username: Kinggimp82
Post Number: 46
im experiencing brightness and would like some tips to treat my room.
i live in an apartment. room is aprox 15' wide x12' deep x 8' high. the right side opens to the kitchen. the left side is a large plate glass window with blinds. the floor is basically indoor outdoor. its like basement carpet over concrete. and the back wall is pretty much empty drywall.
incase you need to know my system is as follows.
FRONT: ascend accoustics CBM-170 SE'S
CENTER: ascend accoustics CMT-340 C SE
SURROUND: None (ascend accoustics HTM-200s soon)
SUB: Hsu STF-2
REC: Pioneer VSX-514
what could i do to treat my room? id imagine a large rug and thick curtains would help. any info would be much appreciated.
thanks,
andrew
Username: Eib_nation
Ohio EIBville
Post Number: 153
Try googling 'acoustic room treatments'.
This is exactly the type of treatment you need to fix the acoustics of any room.
www.gikacoustics.com
Many companies offer these types of products, and you should research many to see which fit's your needs the best.
Good luck.
Username: 865warren
Post Number: 9
As mentioned many companies offer this service so I would compare what they are offering and prices - there are sometimes huge differences...
Username: Nency
Post Number: 97
Most rooms usually fall in the 25% to 75% range for coverage. And this is only for walls and ceiling. This largely depends on the room design, your intentions for the room, and maybe even your style of music or content.
We checked in with Auralex (the acoustic treatment know-it-alls), and they suggest the following generalizations:
• Control rooms for rock, pop, rap, hip-hop, R&B, country, techno, MIDI music, etc. usually benefit from 50% to 75% coverage and mostly absorption.
• Control rooms for jazz, art (classical), choral, acoustic, world and other forms of ensemble music usually benefit from 35% to 50% coverage. The only catch is that the control room be a little more ''dead'' than the main recording or ''live room.'' Diffusion is usually used more generously in these types of control rooms.
• "Live rooms" will vary a lot. Some well-designed live rooms can get by with 20% coverage (or even less!). Most fall into the 25% to 50% range. And this is usually a healthy mix of absorption and diffusion. The most successful live rooms usually have some degree of variability.
• Isolation booths usually call for quite a bit of absorption -- 75% or more.
Need to Register?
Forgot Password?
Enable HTML code in message
