Bose Link
Username: Bisort
Do you guys know the wiring diagram for the Bose Link cables on a SA-3 amp? It has those mini-din 9 pin connectors.
I am just trying to input signal from a different source than a Bose component. I did try the existing "aux" rca connector, but it seems that the signal level for this input must be rather high in order to get the amp to "scream". Thought it may be better using the Bose Link input.
Thanks in advance.
Need to Register?
Forgot Password?
Enable HTML code in message
