Hdmi audio vs. optical
Username: Scottf
Just wondering if hdmi audio was going to sound better than an optical cable. I know that they are both digital, but I don't know if you can get dolby trueHD with an optical cable.
Thanks
Diamond Member
Username: Ecoustics
San Francisco, CA USA
Post Number: 218
You will need to use an HDMI cable and equipment that works with HDMI version 1.3 or later.
Remember your disc (source material) must be encoded with a Dolby TrueHD track, and all components (disc players/receivers) must also be Dolby TrueHD certified to hear Dolby TrueHD.
These articles from Dolby's website will explain things further.
http://www.dolby.com/consumer/technology/trueHD/AVRs/trueHD_avrs_3.html
Username: Matto1985
Waltham, MA USA
Post Number: 15
to my knowledge, there should be no difference in the cables. As you stated, they're both digital.
Need to Register?
Forgot Password?
Enable HTML code in message
