How can I improve quality of display - after connecting TV & laptop with S-video cable?
Username: Talgat
After I connected TV & laptop with s-video cable, TV only shows the wallpaper.
So everytime I want to watch a movie I have to move the movie window to the right outside of my laptop screen so that it shows up on TV.
The problem is - the quality on TV is not nearly as good as it is on my laptop. Even though I was told that it's normal, I want to improve the display quality. I want to make it DVD quality. Are there any tools I can use or maybe adjustments I have to make on TV that will work? Please let me know if you have the answer. Thanks.
Username: Manualrebello
Kalyan, Maharashtra India
Talgat...did you try to decrease the resolution on your laptop...if yes then try to get a video display with TV out. this should help. you can also get an external tv tunder box that should help...try this....
Need to Register?
Forgot Password?
Enable HTML code in message
