DVD - AVI Copyright
Username: Txcphtm
Err I know this isn't exactly on topic but i really need help. I am trying to convert A DVD to AVI so I can watch it on my MP3 player but I dont know how!
Username: Project6
Post Number: 15454
Have you already ripped the DVD to your hard drive?
Username: Txcphtm
Well I tried using DVD Shrink but it didnt bring the Audio Files with it?
Username: Lucky101
HydeabadUnited States
Have you try using Nero burner software. Its the best for ripping dvds. Try this and let me know the feedback.
Username: Rainn
Post Number: 24
i think you use total video converter.
Username: Oposky2006
U.S.A
u can try Pavtube DVD Ripper which always helps me convert dvd to avi or some other formats.
Username: Lion_cing
Post Number: 32
There are several free programs availble. Now you got to make sure you choose the correct size. if your screen is only 2 inches then you need to select 128 x 128 and so on.
Need to Register?
Forgot Password?
Enable HTML code in message
