Is there any good software?
Username: Brunis_19
Hey All,
Do you people know any software which can rip DVD movies into computers? Actually I want to store it in my system, but normally DVD movies are large files and it takes huge space. So if you people know any DVD ripper software please let me know.
Thanks for your help in advance!
Los Angeles, CA
Post Number: 18635
magic dvdripper
Username: Oposky2006
U.S.A
handbrake? a free one
Username: Guile42
Manila, Main Philippines
Post Number: 10
i use magic dvd ripper, very good ripping capability, the only problem is if you are rippin on the secured dvd some possibility of scramble scenes may occur.
Username: Nency
Post Number: 114
Magic DVD Ripper is a very easy and powerful DVD ripping software, which can convert DVD to VCD, SVCD, AVI(DivX), WMV, MP3, iPod and PSP formats or backup DVD to hard drive without any loss of quality. You can then enjoy them anytime without DVD discs or burn them to blank DVD or CD discs using burning software.
Username: Mister_googlehead
Post Number: 13
Magic DVD Ripper is a good choice!
Username: Jim1987
Post Number: 13
I am sure that Windows Media Player has such an option to rip dvd.Go to its menu bar and you will find rip option.I think its the best option to rip dvd.
You also can rip dvd by a software which name is Total Video Converter.Personally I use both of the software and all are working great.
Username: Nency
Post Number: 174
Yes Magic DVD ripping is a good choice but i have Easy DVD Rip provides an easy way to transfer DVD information onto your hard drive. In addition to extracting DVD tracks to MPEG or AVI files, it lets you burn VCDs and SVCDs and extract, discard, or merge specific chapters. You also can customize movie settings such as codec, frame size, audio track, and subtitles.
http://download.cnet.com/Easy-DVD-Rip/3000-2140_4-10441877.html
Username: Djsmith
Post Number: 481
How to Rip & Shrink a FULL DVD movie, Backup a DVD, DVD Shrink, DVD Decrypter, Tutorial
Ripping with DVD Shrink 1.Open DVD Shrink
2.Click "Open Disk"
3.Select your DVD-ROM/Burner where your movie is located, this will load the movie and have DVD Shrink take a couple minutes to analyze.
4.Under "Full Disk Backup" select "Menu", then under "Video"'s drop down menu, selecet "Custom Ratio"
5.Move the slider all the way to the left to shrink it.
6.Select the "Extras" and do the same thing as step 4 & 5, do this for ever single "Extras"
7.If there are any "Unreferenced Material", do the same thing as step 4 & 5
8.Click "Full Disc" square button, at the "Back Up" DVD Screen, select "ISO Image", the "select target image file" is the location and the iso name. Click OK
9."Encoding" will start, which typically can take up considerable time, depending on your computer hardware.
10."Back Up Complete" when its done creating the ISO, reminding of you where the location of the ISO file is located.
II - Burning the ISO with DVD Decrypter 1.Start DVD Decrypter and let it load
2.Select Mode > ISO > Write
3.Select your DVD Burner in the "Destination"
4.Under "Source", select the ISO file created by DVD Shrink in step
5.Click on the big Write Button that has the picture of the "hard drive, green arrow, and dvd" under the "Destination" box
6.This will start the burning
7.That's it!
download links
http://www.afterdawn.com/software/cd_dvd/copy_dvd/dvd_shrink.cfm
http://www.dvddecrypter.org.uk/
Username: Djsmith
Post Number: 482
also try his for blu-rays
http://free.blu-ray-decrypter.com/
Username: Djsmith
Post Number: 483
dvdfab all in one
dvdfab platinum 8106 QT beta
plus Working hack ( dll file)
replace this dll file with one found in program files ... dvdfab directory
( make sure dvdfab is NOT running first.)
remove the (*) between file and com replace with an (.)
http://hotfile*com/dl/1 24260192/718fa3e/msvcr90.rar.html
remove the (*) between dvdfab and com replace it with a (.)
http://forum.dvdfab .com/showthread.php?p=90853#post90853
Username: Djsmith
Post Number: 484
oops posted that twice
Username: Djsmith
Post Number: 485
http://hotfile .com/dl/124260192/718fa3e/msvcr90.rar.html
Username: Mmine
I use Joyoshare Video Converter. It can rip a batch of DVD with or without protections into MP4, AVI, MOV, etc. You can try it ... ...
Username: Swipka6
Music DVD
Need to Register?
Forgot Password?
Enable HTML code in message
